A VAE approach to sample multivariate extremes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Generating accurate extremes from an observational data set is crucial when seeking to estimate risks associated with the occurrence of future extremes which could be larger than those already observed. Applications range from the occurrence of natural disasters to financial crashes. Generative approaches from the machine learning community do not apply to extreme samples without careful adaptation. Besides, asymptotic results from extreme value theory (EVT) give a theoretical framework to model multivariate extreme events, especially through the notion of multivariate regular variation. Bridging these two fields, this paper details a variational autoencoder (VAE) approach for sampling multivariate heavy-tailed distributions, i.e., distributions likely to have extremes of particularly large intensities. We illustrate the relevance of our approach on a synthetic data set and on a real data set of discharge measurements along the Danube river network. The latter shows the potential of our approach for flood risks' assessment. In addition to outperforming the standard VAE for the tested data sets, we also provide a comparison with a competing EVT-based generative approach. On the tested cases, our approach improves the learning of the dependency structure between extremes.
ExtVAE.pdf (1.4 Mo) Télécharger le fichier
hal-04013214 , version 1 (03-03-2023)
hal-04013214 , version 2 (15-06-2023)
  • HAL Id : hal-04013214 , version 2
Nicolas Lafon, Philippe Naveau, Ronan Fablet. A VAE approach to sample multivariate extremes. 2023. ⟨hal-04013214v2⟩
227 Consultations
221 Téléchargements
