A VAE approach to sample multivariate extremes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Rapidly generating accurate extremes from an observational dataset is crucial when seeking to estimate risks associated with the occurrence of future extremes which could be larger than those already observed. Many applications ranging from the occurrence of natural disasters to financial crashes are involved. This paper details a variational auto-encoder (VAE) approach for sampling multivariate extremes. The proposed architecture is based on the extreme value theory (EVT) and more particularly on the notion of multivariate functions with regular variations. Experiments conducted on synthetic datasets as well as on a dataset of discharge measurements along Danube river network illustrate the relevance of our approach.
ExtVAE_ICML2023.pdf (996.93 Ko) Télécharger le fichier
hal-04013214 , version 1 (03-03-2023)
hal-04013214 , version 2 (15-06-2023)
  • HAL Id : hal-04013214 , version 1
Nicolas Lafon, Philippe Naveau, Ronan Fablet. A VAE approach to sample multivariate extremes. 2023. ⟨hal-04013214v1⟩
236 Consultations
236 Téléchargements
