Convergence Rates for Non-Log-Concave Sampling and Log-Partition Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
David Holzmüller
Francis Bach
Sampling from Gibbs distributions p(x) ∝ exp(−V (x)/ε) and computing their log-partition function are fundamental tasks in statistics, machine learning, and statistical physics. However, while efficient algorithms are known for convex potentials V , the situation is much more difficult in the non-convex case, where algorithms necessarily suffer from the curse of dimensionality in the worst case. For optimization, which can be seen as a low-temperature limit of sampling, it is known that smooth functions V allow faster convergence rates. Specifically, for m-times differentiable functions in d dimensions, the optimal rate for algorithms with n function evaluations is known to be O(n −m/d), where the constant can potentially depend on m, d and the function to be optimized. Hence, the curse of dimensionality can be alleviated for smooth functions at least in terms of the convergence rate. Recently, it has been shown that similarly fast rates can also be achieved with polynomial runtime O(n 3.5), where the exponent 3.5 is independent of m or d. Hence, it is natural to ask whether similar rates for sampling and log-partition computation are possible, and whether they can be realized in polynomial time with an exponent independent of m and d. We show that the optimal rates for sampling and log-partition computation are sometimes equal and sometimes faster than for optimization. We then analyze various polynomial-time sampling algorithms, including an extension of a recent promising optimization approach, and find that they sometimes exhibit interesting behavior but no near-optimal rates. Our results also give further insights on the relation between sampling, log-partition, and optimization problems.
sampling_paper-2.pdf (895.58 Ko) Télécharger le fichier
hal-04018103 , version 1 (07-03-2023)
  • HAL Id : hal-04018103 , version 1
David Holzmüller, Francis Bach. Convergence Rates for Non-Log-Concave Sampling and Log-Partition Estimation. 2023. ⟨hal-04018103⟩
33 Consultations
50 Téléchargements
