Learning Optimal Edge Processing with Offloading and Energy Harvesting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern portable devices can execute increasingly sophisticated AI models on sensed data. The complexity of such processing tasks is data-dependent and has relevant energy cost. This work develops an Age of Information markovian model for a system where multiple battery-operated devices perform data processing and energy har- vesting in parallel. Part of their computational burden is offloaded to an edge server which polls devices at given rate. The structural properties of the optimal policy for a single device-server system are derived. They permit to derive a new model-free reinforcement learning method specialized for monotone policies, namely Ordered Q-Learning, providing a fast procedure to learn the optimal policy. The method is oblivious to the devices’ battery capacities, the cost and the value of data batch processing and to the dynamics of the energy harvesting process. Finally, the polling strategy of the server is optimized by combining such policy improvement techniques with stochastic approximation methods. Extensive numerical results provide insight into the system properties and demonstrate that the proposed learning algorithms outperform existing baselines.
fog_Aoi.pdf (652.33 Ko) Télécharger le fichier
hal-04022507 , version 1 (10-03-2023)
hal-04022507 , version 2 (23-03-2023)
Paternité - Pas d'utilisation commerciale
Andrea Fox, Francesco De Pellegrini, Eitan Altman. Learning Optimal Edge Processing with Offloading and Energy Harvesting. MSWiM '23: Int'l ACM Conference on Modeling Analysis and Simulation of Wireless and Mobile Systems, Oct 2023, Montreal Quebec Canada, Canada. pp.83-92, ⟨10.1145/3616388.3617516⟩. ⟨hal-04022507v2⟩
105 Consultations
106 Téléchargements
