A lower bound on the overhead of quantum error correction in low dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We show that a quantum architecture with an error correction procedure limited to geometrically local operations incurs an overhead that grows with the system size, even if arbitrary error-free classical computation is allowed. In particular, we prove that in order to operate a quantum error correcting code in 2D at a logical error rate of $\delta$, a space overhead of $\Omega(\sqrt{\log(1/\delta)})$ is needed for any constant depolarizing noise $p > 0$.
overhead_low-dim.pdf (526.65 Ko) Télécharger le fichier
hal-04023618 , version 1 (10-03-2023)
Nouédyn Baspin, Omar Fawzi, Ala Shayeghi. A lower bound on the overhead of quantum error correction in low dimensions. 2023. ⟨hal-04023618⟩
33 Consultations
14 Téléchargements
