An experimental comparison of software-based power meters: focus on CPU and GPU - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The global energy demand for digital activities is constantly growing. Computing nodes and cloud services are at the heart of these activities. Understanding their energy consumption is an important step towards reducing it. On one hand, physical power meters are very accurate in measuring energy but they are expensive, difficult to deploy on a large scale, and are not able to provide measurements at the service level. On the other hand, power models and vendor-specific internal interfaces are already available or can be implemented on existing systems. Plenty of tools, called software-based power meters, have been developed around the concepts of power models and internal interfaces, in order to report the power consumption at levels ranging from the whole computing node to applications and services. However, we have found that it can be difficult to choose the right tool for a specific need. In this work, we qualitatively and experimentally compare several software-based power meters able to deal with CPU or GPU-based infrastructures. For this purpose, we evaluate them against high-precision physical power meters while executing various intensive workloads. We extend this empirical study to highlight the strengths and limitations of each software-based power meter.
2023060350.pdf (823.4 Ko) Télécharger le fichier
Licence : CC BY SA - Paternité - Partage selon les Conditions Initiales
hal-04030223 , version 1 (20-03-2023)
hal-04030223 , version 2 (03-04-2023)
  • HAL Id : hal-04030223 , version 1
Mathilde Jay, Vladimir Ostapenco, Laurent Lefèvre, Denis Trystram, Anne-Cécile Orgerie, et al.. An experimental comparison of software-based power meters: focus on CPU and GPU. CCGrid 2023 - 23rd IEEE/ACM international symposium on cluster, cloud and internet computing, May 2023, Bangalore, India. pp.1-13. ⟨hal-04030223v1⟩
1014 Consultations
1820 Téléchargements
