High order ADER-IPDG methods for the unsteady advection-diffusion equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
We present a high-order Galerkin method in both space and time for the one-dimensional unsteady advectiondiffusion equation. Three Interior Penalty Discontinuous Galerkin (IPDG) schemes are detailed for the space discretization, while the time integration is performed at the same order of accuracy thanks to an Arbitrary high order DERivatives (ADER) method. The orders of convergence of the three ADER-IPDG methods are carefully examined through numerical illustrations, showing that the approach is consistent, accurate and efficient.
Alexis-TARDIEU-ADER-IPDG.pdf (584.29 Ko) Télécharger le fichier
hal-04032238 , version 1 (16-03-2023)
hal-04032238 , version 2 (15-01-2024)
  • HAL Id : hal-04032238 , version 1
Michel Bergmann, Afaf Bouharguane, Angelo Iollo, Alexis Tardieu. High order ADER-IPDG methods for the unsteady advection-diffusion equation. 2023. ⟨hal-04032238v1⟩
75 Consultations
110 Téléchargements
