Homogeneous Systems Stabilization Based on Convex Embedding
The paper develops control algorithms for a class of affine nonlinear systems using the so-called canonical homogeneous representation. It is demonstrated that such a representation exists for any homogeneous vector field bounded on the unit sphere. It is shown that canonical homogeneous representation is useful for LMI-based control design and stability analysis of nonlinear systems. Theoretical results are supported by numerical examples.
Domains
Automatic Control Engineering
_Homogeneous_Systems_Stabilization_Based_on_Convex_Embedding.pdf (744.47 Ko)
Télécharger le fichier
