Homogeneous Systems Stabilization Based on Convex Embedding ⋆ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2023
The paper develops control algorithms for a class of affine nonlinear systems using the so-called canonical homogeneous representation. It is demonstrated that such a representation exists for any homogeneous vector field bounded on the unit sphere. It is shown that canonical homogeneous representation is useful for LMI-based control design and stability analysis of nonlinear systems. Theoretical results are supported by numerical examples.
Automatique
Homogeneous_Systems_Stabilization_Based_on_Convex_Embedding.pdf (744.47 Ko) Télécharger le fichier
hal-04037564 , version 1 (20-03-2023)
Paternité
  • HAL Id : hal-04037564 , version 1
Konstantin Zimenko, Andrey Polyakov, Denis Efimov. Homogeneous Systems Stabilization Based on Convex Embedding ⋆. Automatica, 2023, 154, pp.111108. ⟨hal-04037564⟩
30 Consultations
64 Téléchargements
