Knowledge Enhanced Graph Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Graph data is omnipresent and has a wide variety of applications, such as in natural science, social networks, or the semantic web. However, while being rich in information, graphs are often noisy and incomplete. As a result, graph completion tasks, such as node classification or link prediction, have gained attention. On one hand, neural methods, such as graph neural networks, have proven to be robust tools for learning rich representations of noisy graphs. On the other hand, symbolic methods enable exact reasoning on graphs. We propose Knowledge Enhanced Graph Neural Networks (KeGNN), a neuro-symbolic framework for graph completion that combines both paradigms as it allows for the integration of prior knowledge into a graph neural network model. Essentially, KeGNN consists of a graph neural network as a base upon which knowledge enhancement layers are stacked with the goal of refining predictions with respect to prior knowledge. We instantiate KeGNN in conjunction with two state-of-the-art graph neural networks, Graph Convolutional Networks and Graph Attention Networks, and evaluate KeGNN on multiple benchmark datasets for node classification.
conference_dsaa.pdf (940.48 Ko) Télécharger le fichier
hal-04041691 , version 1 (27-03-2023)
hal-04041691 , version 2 (23-05-2023)
hal-04041691 , version 3 (30-08-2023)
Luisa Werner, Nabil Layaïda, Pierre Genevès, Sarah Chlyah. Knowledge Enhanced Graph Neural Networks. 2023. ⟨hal-04041691v2⟩
84 Consultations
102 Téléchargements
