Implicit kinetic schemes for the Saint-Venant system
Explicit kinetic schemes applied to the nonlinear shallow water equations have been extensively studied in the past. The novelty of this paper is to investigate an implicit version of such methods in order to improve their stability properties. In the case of a flat bathymetry we obtain a fully implicit kinetic solver satisfying a discrete entropy inequality and keeping the water height non negative without any restriction on the time step. Remarkably, a simplified version of this nonlinear implicit scheme allows to express the update explicitly which we implement in practice. An extension to the 2D case is also discussed. The case of varying bottoms is then dealt with through an iterative solver combined with the hydrostatic reconstruction technique. We show that this scheme preserves the water height positivity under a CFL condition and satisfies a discrete entropy inequality without error term, which is an improvement over its explicit version. Finally we perform some numerical validations underlying the advantages and the computational cost of our strategy.
