Joint Compression and Demosaicking for Satellite Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Image sensors used in real camera systems are equipped with colour filter arrays which sample the light rays in different spectral bands. Each colour channel can thus be obtained separately by considering the corresponding colour filter. While existing compression solutions mostly assume that the captured raw data has been demosaicked prior to compression, in this paper, we describe an end-to-end trainable neural network for joint compression and demosaicking of satellite images. We first introduce a training loss combining a perceptual loss with the classical mean square error, which is shown to better preserve the high-frequency details present in satellite images. We then present a multi-loss balancing strategy which significantly improves the performance of the proposed joint demosaicking-compression solution.
ICASSP_2023_BACCHUS.pdf (571.77 Ko) Télécharger le fichier
hal-04056997 , version 1 (03-04-2023)
hal-04056997 , version 2 (23-05-2023)
  • HAL Id : hal-04056997 , version 1
Pascal Bacchus, Renaud Fraisse, Aline Roumy, Christine Guillemot. Joint Compression and Demosaicking for Satellite Images. ICASSP 2023 - International Conference on Acoustics, Speech, and Signal Processing, Jun 2023, Rhodes (Grèce), Greece. pp.1-5. ⟨hal-04056997v1⟩
65 Consultations
105 Téléchargements
