Combining neural networks and control: potentialities, patterns and perspectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Machine learning tools are widely used for knowledge extraction, modeling, and decision tasks; a range of problems that Control Theory also tackles. Their relations have been largely explored by looking at stochastic control and Markov Decision Processes, due to the proximity of their formulations. However, novel links between machine learning and deterministic control are emerging; combining both approaches, e.g. by performing identification with learning, or controlling the training process. The recent flourishing literature is vast: there is a need to identify challenges, trends and opportunities on this interface. This survey contributes i) to the compared analysis of both fields. ii) Based on literature review, a categorization of combinations of learning and control is drawn. In the control framework, learning has been used for modeling, controllers tuning or adaptation, generating a controller or as a controller itself, for translating complex objectives, or checking controlled systems. Conversely, in the learning framework, control is used for tuning hyperparameters, selecting or generating training data, as the training or decision-making algorithm itself or to guarantee learning properties. iii) Finally, discussions on the literature open novel promising combinations to be explored, such as control of neural networks' training process.
ML_CT_survey-1.pdf (480.5 Ko) Télécharger le fichier
hal-04060379 , version 1 (06-04-2023)
  • HAL Id : hal-04060379 , version 1
Sophie Cerf, Eric Rutten. Combining neural networks and control: potentialities, patterns and perspectives. IFAC 2023 - 22nd World Congress of the International Federation of Automatic Control, International Federation of Automatic Control, Jul 2023, Yokohama, Japan. ⟨hal-04060379⟩
73 Consultations
432 Téléchargements
