Automata, Resolution, and Cut-elimination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Automata, Resolution, and Cut-elimination are three methods to prove the decidability of provability in various logics. The goal of this paper is to understand the relation between these three methods, using Alternating pushdown systems as a unifying example. To this aim, we propose a new Resolution based saturation method for Polarized sequent calculus modulo theory and its associated cut-elimination theorem. We then show how it can be used to prove the decidability of Alternating pushdown systems.
automata.pdf (305.98 Ko) Télécharger le fichier
hal-04063102 , version 1 (13-04-2023)
hal-04063102 , version 2 (13-04-2023)
  • HAL Id : hal-04063102 , version 1
Guillaume Burel, Gilles Dowek, Ying Jiang. Automata, Resolution, and Cut-elimination. 2016. ⟨hal-04063102v1⟩
20 Consultations
14 Téléchargements
