Component-Based Distributed Software Reconfiguration: a Verification-Oriented Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Computing Surveys Année : 2024
Distributed software built from components has become a mainstay of service-oriented applications, which frequently undergo reconfigurations in order to adapt to changes in their operating environment or their functional requirements. Given the complexity of distributed software and the adverse effects of incorrect reconfigurations, a suitable methodology is needed to ensure the correctness of reconfigurations in component- based systems. This survey gives the reader a global perspective over existing formal techniques that pursue this goal. It distinguishes different ways in which formal methods can improve the reliability of reconfigurations, and lists techniques that contribute to solving each of these particular scientific challenges.
main.pdf (668.42 Ko) Télécharger le fichier
hal-04067909 , version 1 (06-11-2023)
Paternité
Hélène Coullon, Ludovic Henrio, Frédéric Loulergue, Simon Robillard. Component-Based Distributed Software Reconfiguration: a Verification-Oriented Survey. ACM Computing Surveys, 2024, 56 (1), pp.1-37. ⟨10.1145/3595376⟩. ⟨hal-04067909⟩
165 Consultations
69 Téléchargements
