A theory independent Curry-De Bruijn-Howard correspondence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Instead of developing a customized typed lambda-calculus for each theory, we attempt to design a general parametric calculus that permits to express the proofs of any theory. This way, the problem of expressing proofs in the lambda-calculus is separated from that of choosing a theory.
curry.pdf (144.6 Ko) Télécharger le fichier
hal-04070185 , version 1 (15-04-2023)
Gilles Dowek. A theory independent Curry-De Bruijn-Howard correspondence. 2012. ⟨hal-04070185⟩
26 Consultations
9 Téléchargements
