Randomized Flexible GMRES with Deflated Restarting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
For high dimensional spaces, a randomized Gram-Schmidt (RGS) algorithm is beneficial in computational costs as well as numerical stability. We apply this dimension reduction technique by random sketching to Krylov subspace methods, e.g. to the generalized minimal residual method (GMRES). We propose a flexible variant of GMRES with the randomized Gram-Schmidt based Arnoldi iteration to produce a set of basis vectors of the Krylov subspace. Even though the Krylov basis is no longer l2 orthonormal, its random projection onto the low dimensional space shows l 2 orthogonality. As a result, it is observed the numerical stability which turns out to be independent of the dimension of the problem even in extreme scale problems. On the other hand, as the Harmonic Ritz values are commonly used in GMRES with deflated restarting to improve convergence, we consider another deflation strategy, for instance disregarding the singular vectors associated with the smallest singular values. We thus introduce a new algorithm of the randomized flexible GMRES with singular value decomposition (SVD) based deflated restarting. At the end, we carry out numerical experiments in the context of compressible turbulent flow simulations. Our proposed approach exhibits a quite competitive numerical behaviour to existing methods while reducing computational costs.
Revision_RGS.pdf (1.48 Mo) Télécharger le fichier
hal-04072873 , version 1 (18-04-2023)
Paternité
  • HAL Id : hal-04072873 , version 1
Yongseok Jang, Laura Grigori, Emeric Martin, Cédric Content. Randomized Flexible GMRES with Deflated Restarting. 2023. ⟨hal-04072873⟩
91 Consultations
166 Téléchargements
