Improved Complexity Results and an Efficient Solution for Connected Multi-Agent Path Finding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Connected multi-agent path finding (CMAPF) consists in computing paths for multiple agents which must reach a goal configuration while remaining connected at all steps. We prove the PSPACEhardness of the problem when the underlying graph is a subgraph of a 3D grid and with range-based connectivity. Moreover, we provide an application of the WHCA * algorithm and show that it outperforms previously given algorithms by an order of magnitude in terms of the sizes of the instances it can handle.
main.pdf (517.83 Ko) Télécharger le fichier
hal-04075393 , version 1 (20-04-2023)
  • HAL Id : hal-04075393 , version 1
Isseïnie Calviac, Ocan Sankur, François Schwarzentruber. Improved Complexity Results and an Efficient Solution for Connected Multi-Agent Path Finding. AAMAS 2023 - 22nd International Conference on Autonomous Agents and Multiagent Systems, May 2023, London, United Kingdom. pp.1-9. ⟨hal-04075393⟩
76 Consultations
63 Téléchargements
