Discrete Weber inequalities and related Maxwell compactness for hybrid spaces over polyhedral partitions of domains with general topology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We prove discrete versions of the first and second Weber inequalities on $\boldsymbol{H}({\bf curl})\cap\boldsymbol{H}({\rm div}_\eta)$-like hybrid spaces spanned by polynomials attached to the faces and to the cells of a polyhedral mesh. The proven hybrid Weber inequalities are optimal in the sense that (i) they are formulated in terms of $\boldsymbol{H}({\bf curl})$- and $\boldsymbol{H}({\rm div}_\eta)$-like hybrid semi-norms designed so as to embed optimally (polynomially) consistent face penalty terms, and (ii) they are valid for face polynomials in the smallest possible stability-compatible spaces. Our results are valid on domains with general, possibly non-trivial topology. In a second part we also prove, within a general topological setting, related discrete Maxwell compactness properties.
hybrid_weber.pdf (333.89 Ko) Télécharger le fichier
hal-04081568 , version 1 (25-04-2023)
hal-04081568 , version 2 (28-12-2023)
hal-04081568 , version 3 (19-02-2024)
  • HAL Id : hal-04081568 , version 1
Simon Lemaire, Silvano Pitassi. Discrete Weber inequalities and related Maxwell compactness for hybrid spaces over polyhedral partitions of domains with general topology. 2023. ⟨hal-04081568v1⟩
168 Consultations
33 Téléchargements
