Scrolling 2D U-Net for the 3D segmentation of the internal carotid artery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
There are several challenges attached with segmenting brain vasculature from angiographic images, including small vessels, uneven contrast, sparse structures, and unique anatomy. Precise and connected segmentations are necessary for analyzing cerebral vasculature and guiding the treatment of cerebral aneurysms. The main challenge is to cover all vessels branching from the main feeding artery in each image.
Author_guidelines_for_ISBI_1_page_abstract_manuscripts.pdf (138.4 Ko) Télécharger le fichier
hal-04090342 , version 1 (09-05-2023)
  • HAL Id : hal-04090342 , version 1
Arya Yazdan-Panah, Guanghui Fu, Didier Dormont, Bruno Stankoff, Olivier Colliot. Scrolling 2D U-Net for the 3D segmentation of the internal carotid artery. 2023. ⟨hal-04090342⟩
22 Consultations
15 Téléchargements
