Testing The Sharpness of Known Error Bounds on The Fast Fourier Transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
The computation of Fast Fourier Transforms (FFTs) in floating-point arithmetic is inexact due to roundings, and for some applications it can prove very useful to know a tight bound on the final error. Although it can be almost attained by specifically built input values, the best known error bound for the Cooley-Tukey FFT seems to be much larger than most actually obtained errors. Also, interval arithmetic can be used to compute a bound on the error committed with a given set of input values, but it is in general considered hampered with large overestimation. We report results of intensive computations to test the two approaches, in order to estimate the numerical performance of state-of-the-art bounds. Surprisingly enough, we observe that while interval arithmetic-based bounds are overestimated, they remain, in our computations, tighter than general known bounds.
mainHaLv0.pdf (350.16 Ko) Télécharger le fichier
hal-04092770 , version 1 (09-05-2023)
hal-04092770 , version 2 (19-07-2023)
Paternité
  • HAL Id : hal-04092770 , version 1
Nicolas Brisebarre, Jean-Michel Muller, Joris Picot. Testing The Sharpness of Known Error Bounds on The Fast Fourier Transform. 2023. ⟨hal-04092770v1⟩
75 Consultations
62 Téléchargements
