Chained estimation for data reduction-driven routing in wireless sensor networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brandon Foubert
  • Fonction : Auteur
  • PersonId : 1254596
Christian Salim
Wireless sensor networks are a precious tool for numerous use cases: studying the fauna and flora, measuring various metrics and so much more. Here we focus specifically on wireless multihop networks, in which the funneling effect is too often responsible of the unbalance of energy consumption, causing in turn nodes failures. In an attempt to mitigate the effects of funneling, the scientific literature proposes among others traffic reduction based on data estimation. The lead idea being that if two phenomena are correlated, then maybe we could estimate the way one goes based on the way the second one do. This effectively reduces the amount of data nodes may have to transmit while preserving the information. We propose in this article a similar method, but here not only limited to a pair of nodes. With our scheme we can reduce the traffic of several nodes over a whole multihop route of communications in a network. We have implemented that scheme and experimented with real hardware which shows good results.
stwimob_23.pdf (274.52 Ko) Télécharger le fichier
hal-04098170 , version 1 (15-05-2023)
  • HAL Id : hal-04098170 , version 1
Brandon Foubert, Christian Salim, Nathalie Mitton. Chained estimation for data reduction-driven routing in wireless sensor networks. WiMob 2023 - 19th International Workshop on Selected Topics in Wireless and Mobile computing, Jun 2023, Montreal, Canada. ⟨hal-04098170⟩
340 Consultations
67 Téléchargements
