Word-Size RMR Trade-offs for Recoverable Mutual Exclusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We present tradeoffs between RMR complexity and memory word size for recoverable mutual exclusion (RME) algorithms using arbitrary synchronization primitives. Assuming that each memory location stores $w$ bits, we show that $n$-process mutual exclusion has an RMR complexity of at least $\Omega(\min\{\log_w n,\log n/\log\log n\})$ on the DSM and the CC model. For $w=(\log n)^{\Omega(1)}$, our lower bound asymptotically matches an upper bound by Katzan and Morrison, whose RME mutual exclusion algorithm employs $w$-bit fetch-and-add operations. Our lower bound is the first one that does not restrict the type of atomic operations that can be executed on a memory location.
general-rme-space-lower-bound.pdf (994 Ko) Télécharger le fichier
hal-04098408 , version 1 (16-05-2023)
  • HAL Id : hal-04098408 , version 1
David Yu Cheng Chan, George Giakkoupis, Philipp Woelfel. Word-Size RMR Trade-offs for Recoverable Mutual Exclusion. 2023. ⟨hal-04098408⟩
50 Consultations
97 Téléchargements
