Mathematical and computational framework for moving and colliding rigid bodies in a Newtonian fluid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
We studied numerically the dynamics of colliding rigid bodies in a Newtonian fluid. The finite element method is used to solve the fluid-body interaction and the fluid motion is described in the Arbitrary-Lagrangian-Eulerian framework. To model the interactions between bodies, we consider a repulsive collision-avoidance model, defined by R. Glowinski. The main emphasis in this work is the generalization of this collision model to multiple rigid bodies of arbitrary shape. Our model first uses a narrow-band fast marching method to detect the set of colliding bodies. Then, collision forces and torques are computed for these bodies via a general expression, which does not depend on their shape. Numerical experiments examining the performance of the narrow-band fast marching method and the parallel execution of the collision algorithm are discussed. We validate our model with literature results and show various applications of colliding bodies in two and three dimensions. In these applications, the bodies move due to forces such as gravity, a fluid flow, or their own actuation. Finally, we present a tool to create arbitrarily shaped bodies in discretized fluid domains, enabling conforming body-fluid interface and allowing to perform simulations of fluid-body interactions with collision treatment in these realistic environments. All simulations are conducted with the Feel++ open source library.
paper_contact (1).pdf (2.52 Mo) Télécharger le fichier
hal-04101291 , version 1 (19-05-2023)
hal-04101291 , version 2 (28-02-2024)
Paternité
Céline Van Landeghem, Luca Berti, Vincent Chabannes, Christophe Prud'Homme, Agathe Chouippe, et al.. Mathematical and computational framework for moving and colliding rigid bodies in a Newtonian fluid. 2023. ⟨hal-04101291v2⟩
117 Consultations
43 Téléchargements
