Total Effects with Constrained Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics and Computing Année : 2024
Recent studies have emphasized the connection between machine learning feature importance measuresand total order sensitivity indices (total effects, henceforth). Feature correlations and the need to avoid unre-stricted permutations make the estimation of these indices challenging. Additionally, there is no establishedtheory or approach for non-Cartesian domains. We propose four alternative strategies for computing totaleffects that account for both dependent and constrained features. Our first approach involves a generalizedwinding stairs design combined with the Knothe-Rosenblatt transformation. This approach, while applicableto a wide family of input dependencies, becomes impractical when inputs are physically constrained. Oursecond approach is a U-statistic that combines the Jansen estimator with a weighting factor. The U-statisticframework allows the derivation of a central limit theorem for this estimator. However, this design is com-putationally intensive. Then, our third approach uses derangements to significantly reduce computationalburden. We prove consistency and central limit theorems for these estimators as well. Our fourth ap-proach is based on a nearest-neighbour intuition and it further reduces computational burden. We test theseestimators through a series of increasingly complex computational experiments with features constrainedon compact and connected domains (circle, simplex), non-compact and non-connected domains (Sierpinskigaskets), we provide comparisons with machine learning approaches and conclude with an application to arealistic simulator.
TotalEffectsConstrainedFeatures_BorognovoPlischkePrieur_hal_V2.pdf (2.95 Mo) Télécharger le fichier
hal-04102882 , version 1 (22-05-2023)
hal-04102882 , version 2 (06-02-2024)
Paternité
Emanuele Borgonovo, Elmar Plischke, Clémentine Prieur. Total Effects with Constrained Features. Statistics and Computing, 2024, 34 (87), pp.1-29. ⟨10.1007/s11222-024-10398-5⟩. ⟨hal-04102882v2⟩
117 Consultations
82 Téléchargements
