High order asymptotic preserving scheme for linear kinetic equations with diffusive scaling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this work, high order asymptotic preserving schemes are constructed and analysed for kinetic equations under a diffusive scaling. The framework enables to consider different cases: the diffusion equation, the advection-diffusion equation and the presence of inflow boundary conditions. Starting from the micro-macro reformulation of the original kinetic equation, high order time integrators are introduced. This class of numerical schemes enjoys the Asymptotic Preserving (AP) property for arbitrary initial data and degenerates when ϵ goes to zero into a high order scheme which is implicit for the diffusion term, which makes it free from the usual diffusion stability condition. The space discretization is also discussed and high order methods are also proposed based on classical finite differences schemes. The Asymptotic Preserving property is analysed and numerical results are presented to illustrate the properties of the proposed schemes in different regimes.
ABC_submit.pdf (1.21 Mo) Télécharger le fichier
hal-04103000 , version 1 (24-05-2023)
  • HAL Id : hal-04103000 , version 1
Megala Anandan, Benjamin Boutin, Nicolas Crouseilles. High order asymptotic preserving scheme for linear kinetic equations with diffusive scaling. 2023. ⟨hal-04103000⟩
48 Consultations
17 Téléchargements
