Stellar wind variability in Cygnus X-1 from high-resolution excess variance spectroscopy with Chandra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2023
Lucia K Härer
  • Fonction : Auteur
Michael L Parker
  • Fonction : Auteur
Victoria Grinberg
  • Fonction : Auteur
Ralf Ballhausen
  • Fonction : Auteur
Zsofi Igo
  • Fonction : Auteur
Amy Joyce
  • Fonction : Auteur
Jörn Wilms
  • Fonction : Auteur
Stellar winds of massive stars are known to be driven by line absorption of UV photons, a mechanism which is prone to instabilities, causing the wind to be clumpy. The clumpy structure hampers wind mass-loss estimates, limiting our understanding of massive star evolution. The wind structure also impacts accretion in high-mass X-ray binary (HMXB) systems. We analyse the wavelength-dependent variability of X-ray absorption in the wind to study its structure. Such an approach is possible in HMXBs, where the compact object serves as an X-ray backlight. We probe different parts of the wind by analysing data taken at superior and inferior conjunction. We apply excess variance spectroscopy to study the wavelength-dependent soft X-ray variability of the HMXB Cygnus X-1 in the low/hard spectral state. Excess variance spectroscopy quantifies the variability of an object above the statistical noise as a function of wavelength, which allows us to study the variability of individual spectral lines. As one of the first studies, we apply this technique to high-resolution gratings spectra provided by Chandra, accounting for various systematic effects. The frequency dependence is investigated by changing the time binning. The strong orbital phase dependence we observe in the excess variance is consistent with column density variations predicted by a simple model for a clumpy wind. We identify spikes of increased variability with spectral features found by previous spectroscopic analyses of the same data set, most notably from silicon in over-dense clumps in the wind. In the silicon line region, the variability power is redistributed towards lower frequencies, hinting at increased line variability in large clumps. In prospect of the microcalorimetry missions that are scheduled to launch within the next decade, excess variance spectra present a promising approach to constrain the wind structure.
aa46669-23.pdf (2.41 Mo) Télécharger le fichier
hal-04103930 , version 1 (05-05-2024)
Paternité
Lucia K Härer, Michael L Parker, Ileyk El Mellah, Victoria Grinberg, Ralf Ballhausen, et al.. Stellar wind variability in Cygnus X-1 from high-resolution excess variance spectroscopy with Chandra. Astronomy and Astrophysics - A&A, 2023, 680, pp.A72. ⟨10.1051/0004-6361/202346669⟩. ⟨hal-04103930⟩
36 Consultations
0 Téléchargements
