Risk-Sensitive Extended Kalman Filter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In robotics, designing robust algorithms in the face of estimation uncertainty is a challenging task. Indeed, controllers often do not consider the estimation uncertainty and only rely on the most likely estimated state. Consequently, sudden changes in the environment or the robot's dynamics can lead to catastrophic behaviors. In this work, we present a risk-sensitive Extended Kalman Filter that allows doing outputfeedback Model Predictive Control (MPC) safely. This filter adapts its estimation to the control objective. By taking a pessimistic estimate concerning the value function resulting from the MPC controller, the filter provides increased robustness to the controller in phases of uncertainty as compared to a standard Extended Kalman Filter (EKF). Moreover, the filter has the same complexity as an EKF, so that it can be used for real-time model-predictive control. The paper evaluates the risk-sensitive behavior of the proposed filter when used in a nonlinear model-predictive control loop on a planar drone and industrial manipulator in simulation, as well as on an external force estimation task on a real quadruped robot. These experiments demonstrate the abilities of the approach to improve performance in the face of uncertainties significantly.
Risk-Sensitive Extended Kalman Filter.pdf (1016.33 Ko) Télécharger le fichier
hal-04107207 , version 1 (26-05-2023)
  • HAL Id : hal-04107207 , version 1
Armand Jordana, Avadesh Meduri, Etienne Arlaud, Justin Carpentier, Ludovic Righetti. Risk-Sensitive Extended Kalman Filter. 2023. ⟨hal-04107207⟩
24 Consultations
62 Téléchargements
