The TeamPlay Project: Analysing and Optimising Time, Energy, and Security for Cyber-Physical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Non-functional properties, such as energy, time, and security (ETS) are becoming increasingly important in Cyber-Physical Systems (CPS) programming. This article describes TeamPlay, a research project funded under the EU Horizon 2020 programme between January 2018 and June 2021. TeamPlay aimed to provide the system designer with a toolchain for developing embedded applications where ETS properties are first-class citizens, allowing the developer to reflect directly on energy, time and security properties at the source code level. In this paper we give an overview of the TeamPlay methodology, introduce the challenges and solutions of our approach and summarise the results achieved. Overall, applying our TeamPlay methodology led to an improvement of up to 18% performance and 52% energy usage over traditional approaches.
TeamPlay-platform_DATE-2023.pdf (164.57 Ko) Télécharger le fichier
hal-04108237 , version 1 (31-05-2023)
Paternité
  • HAL Id : hal-04108237 , version 1
Benjamin Rouxel, Christopher Brown, Emad Ebeid, Kerstin Eder, Heiko Falk, et al.. The TeamPlay Project: Analysing and Optimising Time, Energy, and Security for Cyber-Physical Systems. DATE 2023 - Design, Automation and Test in Europe Conference (MPP - Multi-Partner Projects Track ), Apr 2023, Antwerp, Belgium. pp.1-6. ⟨hal-04108237⟩
55 Consultations
34 Téléchargements
