TKE model involving the distance to the wall. Part 1: the relaxed case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider a steady-state turbulent RANS model that couples the equation for the velocity-pressure field to the equation for the turbulent kinetic energy, with eddy viscosities vanishing at the boundary like d(x, Γ) η and d(x, Γ) β , where 0 < η, β < 1. We find critical values η c and β c for which the system has a weak solution obtained as the limit of viscous regularizations for 0 < η < η c , 0 < β < β c .
TKE_Degeneree_eta.pdf (361.26 Ko) Télécharger le fichier
hal-04111072 , version 1 (31-05-2023)
hal-04111072 , version 2 (13-12-2023)
Paternité
  • HAL Id : hal-04111072 , version 2
Chérif Amrouche, Guillaume Leloup, Roger Lewandowski. TKE model involving the distance to the wall. Part 1: the relaxed case. 2023. ⟨hal-04111072v2⟩
81 Consultations
23 Téléchargements
