Trajectory Tracking in Linear Complementarity Systems with and without State-Jumps: A Passivity Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This work is largely concerned with trajectory tracking in linear complementarity systems (LCS). The main analytical tool for stability analysis and control design is passivity and the associated linear matrix inequalities (LMIs). Cases with and without state jumps, with and without parametric uncertainties, are analysed. Theoretical findings are illustrated with many examples from circuits with set-valued, nonsmooth electronic components, networks with unilateral interactions, and mechanical systems with unilateral springs.
Trajectory Tracking in Linear Complementarity Systems with and without State-Jumps: A Passivity Approach.pdf (2.69 Mo) Télécharger le fichier
hal-04113986 , version 1 (01-06-2023)
hal-04113986 , version 2 (21-02-2024)
Paternité
  • HAL Id : hal-04113986 , version 2
Aya Younes, Félix Miranda-Villatoro, Bernard Brogliato. Trajectory Tracking in Linear Complementarity Systems with and without State-Jumps: A Passivity Approach. 2024. ⟨hal-04113986v2⟩
91 Consultations
52 Téléchargements
