WCET analysis with procedure arguments as parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parametric Worst-Case Execution Time (WCET) is a static analysis that computes a WCET formula that depends on various parameters. The formula can be used off-line for fast parameter space exploration, and on-line for adaptive scheduling. In this work, we propose a technique that, by static analysis of binary code, automatically produces a formula that represents the WCET of a procedure as a function of the procedure arguments. The formula captures how the control-flow, and thus the WCET, depends on the argument values due to arguments appearing in branch conditions (loop conditions or if-then-else conditions). We use the TACLeBench benchmark programs to illustrate the impact of procedure arguments on the WCET. Our tool generates C code with bounded WCET that can be embedded in the analysed program to evaluate the formula on-line. We show that, for some programs, the potential gain is significantly larger than the cost of evaluating the formula, thus opening the possibility of adaptive scheduling.
main.pdf (436.25 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-04118213 , version 1 (06-06-2023)
Sandro Grebant, Clément Ballabriga, Julien Forget, Giuseppe Lipari. WCET analysis with procedure arguments as parameters. RTNS 2023: The 31st International Conference on Real-Time Networks and Systems, Jun 2023, Dortmund, Germany. pp.11-22, ⟨10.1145/3575757.3593655⟩. ⟨hal-04118213⟩
102 Consultations
87 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
