Flatness approach for the boundary controllability of a system of heat equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We study the boundary controllability of $2 × 2$ system of heat equations by using a flatness approach. According to the relation between the diffusion coefficients of the heat equation, it is known that the system can be not null-controllable or null-controllable for any $T > T_0$ where $T_0 \in [0, \infty]$. Here we recover this result in the case that $T_0 \in [0, \infty)$ by using the flatness method, and we obtain an explicit formula for the control and for the corresponding solutions. In particular, the state and the control have Gevrey regularity in time and in space.
ColleLoheacTakahashi2023.pdf (342.07 Ko) Télécharger le fichier
hal-04119834 , version 1 (06-06-2023)
  • HAL Id : hal-04119834 , version 1
Blaise Colle, Jérôme Lohéac, Takéo Takahashi. Flatness approach for the boundary controllability of a system of heat equations. 2023. ⟨hal-04119834⟩
133 Consultations
54 Téléchargements
