Complex Wrinkle Field Evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2023
We propose a new approach for representing wrinkles, designed to capture complex and detailed wrinkle behavior on coarse triangle meshes, called Complex Wrinkle Fields. Complex Wrinkle Fields consist of an almost-everywhere-unit complex-valued phase function over the surface; a frequency one-form; and an amplitude scalar, with a soft compatibility condition coupling the frequency and phase. We develop algorithms for interpolating between two such wrinkle fields, for visualizing them as displacements of a Loop-subdivided refinement of the base mesh, and for making smooth local edits to the wrinkle amplitude, frequency, and/or orientation. These algorithms make it possible, for the first time, to create and edit animations of wrinkles on triangle meshes that are smooth in space, evolve smoothly through time, include singularities along with their complex interactions, and that represent frequencies far finer than the surface resolution.
CWF_Chen_2023.pdf (21.43 Mo) Télécharger le fichier
hal-04130767 , version 1 (16-06-2023)
Paternité
Zhen Chen, Danny M Kaufman, Mélina Skouras, Etienne Vouga. Complex Wrinkle Field Evolution. ACM Transactions on Graphics, 2023, 42 (4), pp.72:1-19. ⟨10.1145/3592397⟩. ⟨hal-04130767⟩
58 Consultations
100 Téléchargements
