Data-driven Reconstruction of Partially Observed Dynamical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
The state of the atmosphere, or of the ocean, cannot be exhaustively observed. Crucial parts might remain out of reach of proper monitoring. Also, defining the exact set of equations driving the atmosphere and ocean is virtually impossible because of their complexity. Hence, the goal of this paper is to obtain predictions of a partially observed dynamical system, without knowing the model equations. In this data-driven context, the article focuses on the Lorenz-63 system, where only the second and third components are observed, and access to the equations is not allowed. To account to those strong constraints, a combination of machine learning and data assimilation techniques is proposed. The key aspects are the following: the introduction of latent variables, a linear approximation of the dynamics, and a database that is updated iteratively, maximising the innovation likelihood. We find that the latent variables inferred by the procedure are related to the successive derivatives of the observed components of the dynamical system. The method is also able to reconstruct accurately the local dynamics of the partially observed system. Overall, the proposed methodology is simple, easy to code, and gives promising results, even in the case of small amounts of observations.
egusphere-2022-1316.pdf (4.88 Mo) Télécharger le fichier
hal-04131312 , version 1 (29-11-2022)
hal-04131312 , version 2 (16-06-2023)
Pierre Tandeo, Pierre Ailliot, Florian Sévellec. Data-driven Reconstruction of Partially Observed Dynamical Systems. 2022. ⟨hal-04131312v1⟩
113 Consultations
100 Téléchargements
