Adaptive Task Sharing in Collaboarative Robotics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In a flexible collaborative task sharing framework, it is necessary to take situation awareness issues into account. A robot must be able to "understand" the context of the collaboration, especially the difficulty of the task, the willingness of the human to collaborate or his availability. We propose to implement a robotic decision process based on the situation awareness model defined by Endsley. An experiment has been carried out to illustrate an adaptive collaboration in which the robot takes the initiative and fulfill the task that was assigned to the human.
Adaptive task sharing in collaborative robotics V2.pdf (287.64 Ko) Télécharger le fichier
hal-04133473 , version 1 (19-06-2023)
  • HAL Id : hal-04133473 , version 1
Thomas Faure, Hugo Decroux, Jean-Marc Salotti. Adaptive Task Sharing in Collaboarative Robotics. ICRA23 - Workshop: Cognitive Modeling in Robot Learning for Human Robot-Interactions, Jun 2023, Londres, United Kingdom. https://sites.google.com/view/cognitive-modeling-icra2023-ws/contributions. ⟨hal-04133473⟩
46 Consultations
29 Téléchargements
