Global exact optimisations for chloroplast structural haplotype scaffolding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms for Molecular Biology Année : 2024
Optimisation exacte et globale pour l'échafaudage d'haplotypes structuraux de chloroplastes
Background Scaffolding is an intermediate stage of fragment assembly. It consists in orienting and ordering the contigs obtained by the assembly of the sequencing reads. In the general case, the problem has been largely studied with the use of distances data between the contigs. Here we focus on a dedicated scaffolding for the chloroplast genomes. As these genomes are small, circular and with few specific repeats, numerous approaches have been proposed to assemble them. However, their specificities have not been sufficiently exploited. Results We give a new formulation for the scaffolding in the case of chloroplast genomes as a discrete optimisation problem, that we prove the decision version to be N P-Complete. We take advantage of the knowledge of chloroplast genomes and succeed in expressing the relationships between a few specific genomic repeats in mathematical constraints. Our approach is independent of the distances and adopts a genomic regions view, with the priority on scaffolding the repeats first. In this way, we encode the structural haplotype issue in order to retrieve several genome forms that coexist in the same chloroplast cell. To solve exactly the optimisation problem, we develop an integer linear program that we implement in Python3 package khloraascaf. We test it on synthetic data to investigate its performance behaviour and its robustness against several chosen difficulties. Conclusions We succeed to model biological knowledge on genomic structures to scaffold chloroplast genomes. Our results suggest that modelling genomic regions is sufficient for scaffolding repeats and is suitable for finding several solutions corresponding to several genome forms.
khloraascaf.pdf (1.1 Mo) Télécharger le fichier
Licence : CC BY SA - Paternité - Partage selon les Conditions Initiales
hal-04134429 , version 1 (20-06-2023)
hal-04134429 , version 2 (27-06-2023)
hal-04134429 , version 3 (05-03-2024)
Victor Epain, Rumen Andonov. Global exact optimisations for chloroplast structural haplotype scaffolding. Algorithms for Molecular Biology, 2024, 19 (5), pp.1-35. ⟨10.1186/s13015-023-00243-1⟩. ⟨hal-04134429v3⟩
79 Consultations
30 Téléchargements
