Feedback Interconnections of Passive Linear Cone Complementarity Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper is largely concerned with generic interconnections of a class of passive nonsmooth nonlinear dynamical systems, namely linear cone complementarity systems (LCCS). Criteria which guarantee the passivity of the interconnection are given. Asymptotic stability is studied in a particular case. Examples from nonsmooth circuits and switching DAEs (Differential Algebraic Equations) illustrate the theory.
Report.pdf (376.8 Ko) Télécharger le fichier
hal-04137144 , version 1 (22-06-2023)
hal-04137144 , version 2 (02-04-2024)
Paternité
  • HAL Id : hal-04137144 , version 1
Bernard Brogliato, Aneel Tanwani. Feedback Interconnections of Passive Linear Cone Complementarity Systems. 2023. ⟨hal-04137144v1⟩
83 Consultations
56 Téléchargements
