Active Design of Diffuse Acoustic Fields in Enclosures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Journal of the Acoustical Society of America Année : 2024
This paper presents a numerical framework for designing diffuse fields in rooms of any shape and size, driven at arbitrary frequencies. That is, we aim at overcoming the Schroeder frequency limit for generating diffuse fields in an enclosed space. We formulate the problem as a Tikhonov regularized inverse problem and propose a lowrank approximation of the spatial correlation that results in significant computational gains. Our approximation is applicable to arbitrary sets of target points and allows us to produce an optimal design at a computational cost that grows only linearly with the (potentially large) number of target points. We demonstrate the feasibility of our approach through numerical examples where we approximate diffuse fields at frequencies well below the Schroeder limit.
jasa23b.pdf (1.57 Mo) Télécharger le fichier
hal-04138504 , version 1 (23-06-2023)
Wilkins Aquino, Jerry Rouse, Marc Bonnet. Active Design of Diffuse Acoustic Fields in Enclosures. The Journal of the Acoustical Society of America, 2024, 155, pp.1297-1307. ⟨10.1121/10.0024770⟩. ⟨hal-04138504⟩
52 Consultations
21 Téléchargements
