Locally Homogeneous Finite-time Stabilization of Quasi-Linear Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this paper, an algorithm of a local finite-time control design is developed for a class of quasi-linear systems. The design procedure is essentially based on the concept of generalized homogeneity and the convex embedding technique. The adjustment of control parameters is realized by solving a system of linear matrix inequalities (LMIs). Theoretical results are supported by numerical simulations.
Automatique
Mericel_CDC.pdf (650.25 Ko) Télécharger le fichier
hal-04139119 , version 1 (23-06-2023)
Paternité
  • HAL Id : hal-04139119 , version 1
Mericel Ayamou, Andrey Polyakov, Nicolás Espitia. Locally Homogeneous Finite-time Stabilization of Quasi-Linear Systems. 2023. ⟨hal-04139119⟩
270 Consultations
80 Téléchargements
