Stability of optimal shapes and convergence of thresholding algorithms in linear and spectral optimal control problems: Supplementary material - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We address the convergence of thresholding schemes for spectral optimisation problems and linear control problems.
CMP-2022Supp.pdf (386.91 Ko) Télécharger le fichier
hal-04140334 , version 1 (25-06-2023)
Paternité
  • HAL Id : hal-04140334 , version 1
Antonin Chambolle, Idriss Mazari-Fouquer, Yannick Privat. Stability of optimal shapes and convergence of thresholding algorithms in linear and spectral optimal control problems: Supplementary material. 2023. ⟨hal-04140334⟩
48 Consultations
21 Téléchargements
