The surjection property and computable type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We provide a detailed study of two properties of spaces and pairs of spaces, the surjection property and the-surjection property, that were recently introduced to characterize the notion of computable type arising from computability theory. For a class of spaces including the finite simplicial complexes, we develop techniques to prove or disprove these properties using homotopy and homology theories, and give applications of these results. In particular, we answer an open question on the computable type property, showing that it is not preserved by taking products.
article.pdf (487.64 Ko) Télécharger le fichier
hal-04140772 , version 1 (26-06-2023)
Paternité
Djamel Eddine Amir, Mathieu Hoyrup. The surjection property and computable type. 2023. ⟨hal-04140772⟩
24 Consultations
22 Téléchargements
