Topological signatures of periodic-like signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We present a method to construct signatures of periodic-like data. Based on topological considerations, our construction encodes information about the order and values of local extrema. Its main strength is robustness to reparametrisation of the observed signal, so that it depends only on the form of the periodic function. The signature converges as the observation contains increasingly many periods. We show that it can be estimated from the observation of a single time series using bootstrap techniques.
2306.13453.pdf (976.94 Ko) Télécharger le fichier
hal-04140929 , version 1 (26-06-2023)
Wojciech Reise, Bertrand Michel, Frédéric Chazal. Topological signatures of periodic-like signals. 2023. ⟨hal-04140929⟩
23 Consultations
30 Téléchargements
