Construction of polynomial particular solutions of linear constant-coefficient partial differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers & Mathematics with Applications Année : 2024
This paper introduces general methodologies for constructing closed-form solutions to linear constant-coefficient partial differential equations (PDEs) with polynomial right-hand sides in two and three spatial dimensions. Polynomial solutions have recently regained significance in the development of numerical techniques for evaluating volume integral operators and also have potential applications in certain kinds of Trefftz finite element methods. The equations covered in this work include the isotropic and anisotropic Poisson, Helmholtz, Stokes, linearized Navier-Stokes, stationary advection-diffusion, elastostatic equations, as well as the time-harmonic elastodynamic and Maxwell equations. Several solutions to complex PDE systems are obtained by a potential representation and rely on the Helmholtz or Poisson solvers. Some of the cases addressed, namely Stokes flow, Maxwell’s equations and linearized Navier-Stokes equations, naturally incorporate divergence constraints on the solution. This article provides a generic pattern whereby solutions are constructed by leveraging solutions of the lowest-order part of the partial differential operator (PDO). With the exception of anisotropic material tensors, no matrix inversion or linear system solution is required to compute the solutions. This work is accompanied by a freely-available Julia library, ElementaryPDESolutions.jl, which implements the proposed methodology in an efficient and user-friendly format.
cma24.pdf (518.8 Ko) Télécharger le fichier
hal-04146453 , version 1 (30-06-2023)
hal-04146453 , version 2 (21-12-2023)
hal-04146453 , version 3 (25-02-2024)
hal-04146453 , version 4 (16-03-2024)
Thomas G. Anderson, Marc Bonnet, Luiz M. Faria, Carlos Pérez-Arancibia. Construction of polynomial particular solutions of linear constant-coefficient partial differential equations. Computers & Mathematics with Applications, In press, 162C, pp.94-103. ⟨10.1016/j.camwa.2024.02.045⟩. ⟨hal-04146453v3⟩
Collections
ENSTA
51 Consultations
87 Téléchargements
