Electromagnetic waves propagation in thin heterogenous coaxial cables. Comparaison between 3D and 1D models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This work deals with wave propagation into a coaxial cable, which can be modeled by the 3D Maxwell equations or 1D simplified models. The usual one, called the telegrapher's model, is a 1D wave equation on the electrical voltage and current. We derived a more accurate model from the Maxwell equations that takes into account dispersive effects. These two models aim to be a good approximation of the 3D electromagnetic fields in the case where the thinness of the cable is small. We perform some numerical simulations of the 3D Maxwell equations and of the 1D simplified models in order to validate the usual model and the new one. Moreover, we show that while the usual telegrapher model is of order one with respect to the thinness of the cable, the dispersive 1D model is of order two.
Version3.pdf (2.39 Mo) Télécharger le fichier
hal-04147142 , version 1 (30-06-2023)
hal-04147142 , version 2 (30-06-2023)
hal-04147142 , version 3 (27-10-2023)
Paternité
  • HAL Id : hal-04147142 , version 1
Geoffrey Beck, Akram Beni Hamad. Electromagnetic waves propagation in thin heterogenous coaxial cables. Comparaison between 3D and 1D models. 2023. ⟨hal-04147142v1⟩
136 Consultations
64 Téléchargements
