Moment inequalities for sums of weakly dependent random fields
We derive both Azuma-Hoeffding and Burkholder-type inequalities for partial sums over a rectangular
grid of dimension $d$ of a random field satisfying a weak dependency assumption of projective type:
the difference between the expectation of an element of the random field and its conditional expectation
given the rest of the field at a distance more than $\delta$ is bounded, in $L^p$
distance, by a known decreasing function of $\delta$. The analysis is based on the combination of a multi-scale approximation of random sums by martingale difference sequences, and
of a careful decomposition of the domain. The obtained results extend previously known bounds
under comparable hypotheses, and do not use the assumption of commuting filtrations.
REVISION_bernoulli_dependentspatialsprocesses.pdf (270.73 Ko)
Télécharger le fichier
