Moment inequalities for sums of weakly dependent random fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We derive both Azuma-Hoeffding and Burkholder-type inequalities for partial sums over a rectangular grid of dimension $d$ of a random field satisfying a weak dependency assumption of projective type: the difference between the expectation of an element of the random field and its conditional expectation given the rest of the field at a distance more than $\delta$ is bounded, in $L^p$ distance, by a known decreasing function of $\delta$. The analysis is based on the combination of a multi-scale approximation of random sums by martingale difference sequences, and of a careful decomposition of the domain. The obtained results extend previously known bounds under comparable hypotheses, and do not use the assumption of commuting filtrations.
REVISION_bernoulli_dependentspatialsprocesses.pdf (270.73 Ko) Télécharger le fichier
hal-04150509 , version 1 (04-07-2023)
Gilles Blanchard, Alexandra Carpentier, Oleksandr Zadorozhnyi. Moment inequalities for sums of weakly dependent random fields. 2023. ⟨hal-04150509⟩
16 Consultations
30 Téléchargements
