Using Population Based Kalman Estimator to Model COVID-19 Epidemic in France: Estimating the Effects of Non-Pharmaceutical Interventions on the Dynamics of Epidemic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The international journal of biostatistics Année : 2023
In response to the ongoing COVID-19 pandemic caused by SARS-CoV-2, governments are taking a wide range of non-pharmaceutical interventions (NPI). These measures include interventions as stringent as strict lockdown but also school closure, bar and restaurant closure, curfews and barrier gestures i.e . social distancing. Disentangling the effectiveness of each NPI is crucial to inform response to future outbreaks. To this end, we first develop a multi-level estimation of the French COVID-19 epidemic over a period of one year. We rely on a global extended Susceptible-Infectious-Recovered (SIR) mechanistic model of the infection including a dynamical (over time) transmission rate containing a Wiener process accounting for modeling error. Random effects are integrated following an innovative population approach based on a Kalman-type filter where the log-likelihood functional couples data across French regions. We then fit the estimated time-varying transmission rate using a regression model depending on NPI, while accounting for vaccination coverage, apparition of variants of concern (VoC) and seasonal weather conditions. We show that all NPI considered have an independent significant effect on the transmission rate. We additionally demonstrate a strong effect from weather conditions which decrease transmission during the summer period, and also estimate increased transmissibility of VoCs.
2021.07.09.21260259v4.full.pdf (2.89 Mo) Télécharger le fichier
hal-04151651 , version 1 (12-07-2023)
Annabelle Collin, Boris P. Hejblum, Carole Vignals, Laurent Lehot, Rodolphe Thiébaut, et al.. Using Population Based Kalman Estimator to Model COVID-19 Epidemic in France: Estimating the Effects of Non-Pharmaceutical Interventions on the Dynamics of Epidemic. The international journal of biostatistics, inPress, ⟨10.1515/ijb-2022-0087⟩. ⟨hal-04151651⟩
193 Consultations
55 Téléchargements
