Recovering Headerless Frames in LR-FHSS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Long-Range Frequency Hopping Spread Spectrum (LR-FHSS) is a recent modulation designed for communications from low-power ground end-devices to Low-Earth Orbit (LEO) satellites. To decode a frame, an LR-FHSS gateway must receive at least one header replica and a large proportion of payload fragments. However, LR-FHSS headers will likely be lost when there are many concurrent transmissions. In this paper, we motivate the header loss problem with an analytical model, propose a linear programming model to extract headerless frames and design a cost-effective sliding window heuristic. Simulation results show that our approach exhibits near-optimal headerless detection and extraction results while ensuring a low computational cost. The proposed method is, therefore, suitable for future LR-FHSS gateways located onboard resource-constrained LEO satellites.
_EWSN__LoRaHeaderLess.pdf (669.01 Ko) Télécharger le fichier
hal-04152028 , version 1 (05-07-2023)
Paternité
  • HAL Id : hal-04152028 , version 1
Juan Andrés A Fraire, Alexandre Guitton, Oana Iova. Recovering Headerless Frames in LR-FHSS. International Conference on Embedded Wireless Systems and Networks, Sep 2023, Rende, Italy. pp.1-11. ⟨hal-04152028⟩
80 Consultations
106 Téléchargements
