Work in Progress: Thwarting Timing Attacks in Microcontrollers using Fine-grained Hardware Protections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Timing side-channels are an identified threat for security critical software. Existing countermeasures have a cost either on the hardware requirements or execution time. We focus on low-cost microcontrollers that have a very low computational capacity. Although these processors do not feature out-of-order execution or speculation, they remain vulnerable to timing attacks exploiting the varying latencies of ALU operations or memory accesses. We propose to augment the RISC-V ISA with security primitives that have a guaranteed timing behavior. These primitives allow constant time ALU operations and memory accesses that do not alter the state of the cache. Our approach has a low overhead in terms of hardware cost, binary code size, and execution time both for the constant time secure program and other programs running concurrently on the same hardware.
silm2023-cache-protection.pdf (289.78 Ko) Télécharger le fichier
hal-04155139 , version 1 (07-07-2023)
Paternité
  • HAL Id : hal-04155139 , version 1
Nicolas Gaudin, Jean-Loup Hatchikian-Houdot, Frédéric Besson, Pascal Cotret, Gogniat Guy, et al.. Work in Progress: Thwarting Timing Attacks in Microcontrollers using Fine-grained Hardware Protections. 2023 IEEE European Symposium on Security and Privacy Workshops (EuroS&PW), Jul 2023, Delft, Netherlands. pp.1-7. ⟨hal-04155139⟩
88 Consultations
96 Téléchargements
